Sorry can't answer that for you. For me I would say yes. I filled up the tank of my auto last month. Checked the log book, last time before that was Sept. 2021! Nearly all my other transportation needs were via my ebikes so that $625 purchase would be an easy ROI after a few months of use for me.torker said:Is it worth it?
I started a new project also, similar FS, in an effort to get back some comfort and safety in the beat up roads around here. The three main challenges are: 1) Battery placement real estate (as mentioned above); 2) Fenders; 3) Rear rack. That is for urban commuter use/ car replacement use. If you are just building for offroad fun you probably don't need fenders or rack.torker said:I want to move my setup from my Rincon hardtail to it.
torker said:They are pretty rare here in Wichita. I just don't want to spend a grand for a donor. I know the higher end bikes ride good and are great to start a build. Just not in the budget. Actually 625 is a lot for me fsr.jpg
Another view. Hopefully I can do similar with this although the frame is different. But it is a Cadillac to me...
Seems to be a constant worry.torker said:"Is it worth it?"
"625.00 is a lot for me .. "
"Actually 625 is a lot for me"
"But it is a Cadillac to me..."
E-HP said:torker said:They are pretty rare here in Wichita. I just don't want to spend a grand for a donor. I know the higher end bikes ride good and are great to start a build. Just not in the budget. Actually 625 is a lot for me fsr.jpg
That bike looks good. That's probably one of the last years with straight tubes, so better for what you want to do. They went to those curvy tubes in 2007 or so, which looks like it's harder to get a decent battery mounted on. I never understood what the benefit is for curvy tubes. Maybe makes sense on the top tube, but why on the downtube?:
https://sfbay.craigslist.org/sby/bik/d/santa-clara-2007-specialized/7454492273.html
dogman dan said:I'd look hardest at that fork. These days its hard to get a really good replacement fork for straight tube headsets. For street, or moderate trail rides, the shorter travel knock off brand forks can be ok. But if you need long travel, then you need that fork to be in very good shape.
Having said that, the fork alone could be worth half that price. Especially if its a top of the line replacement, not the original.
99t4 said:Seems to be a constant worry.torker said:"Is it worth it?"
If it's going to present problems paying the rent, putting food on the table, keeping up with your base responsibilities, then you shouldn't do it.
But if you even halfway like bicycling, then riding a high-quality well-designed well-built bicycle made with good materials and good componentry will fill you with indescribable joy each time you set out to ride. Something you cannot ascribe a monetary value to.
