zombiess
I decided to punish myself and build another 20 IRFB4115 controllers but this time they EB324 which is an entirely new design using the GPM8F chip set just like the other EB3xx controllers do. Was wondering if anyone else has played around with these. I should have one finished up on Sunday night to play with and test. Heat sinking is much better improved on these because they mount to the side of the case vs just the top. I will report back performance of course, just curious if anyone else has played around with them. I prefer the EB3xx based controllers to the EB2xx which use the older XCKJ8B116A chip set because the GPM8F chips seem to do a better job at controlling phase current.
Here is a picture of one of the boards I've built up the traces on to show how different they are.
Really nice feature is larger phase wire holes so it's super easy to fit the 8 AWG wire I use. They split the bottom phase between sides which I'm not the most fond of design wise, but then again from a design stand point these controllers are kinda like a hammer. None the less they are proven and get the job done cheaply with a lot of features/power for a good price when modified.
Those blue things are 1uF pulse rated polypropylene snubber caps I am adding to the rails if you were wondering. Trace build up is done with solid 10 AWG copper wire.
