Hummina Shadeeba
markz said:Hummina Shadeeba said:i got 233mm for the flange from hole to hole. i'll look for the thread and see what others got. but should i do 1x or radial you think and 12 or 13 gauge ok?
also i have two 20" rims and one says its 390mm ird but i line it up with the other rim that's written up as 388 and it's got a greater distance not less. Envy rim at 390 and the Promax claims 388. i see the Promax at at least 400mm assuming the envy is even 390
1X is ideal, but smaller rim 20" may need a radial lace. I would start off with a 1X and see how it goes with a dry run and if its too tight go for a radial. Looking at spoke angle from hers://ebikes.ca/tools/spoke-calc.html?pair=false&rim=20P17
Spoke Angle: This is the angle between the spoke and the tangent line of the rim. Generally speaking, if the angle is more than 80 degrees then it can be laced with relative ease. If the angle is less than 75 degrees, then the spoke nipples will have some difficulty in angling in the same direction as the spokes, and you may need to either put a bend in the spoke so that it enters the rim a bit more radially, or drill out the rim holes slightly larger so that the nipples have more freedom to pivot. Angles less than about 70 degrees are quite problematic and best avoided.
Two rims that close you wont notice any difference and its measured from just beyond the spoke hole inside the rim to the other side.
wow great link thanks. seems 1x is too sharp an angle and i'll do radial. just seems weird as its a big no-no on a front wheel with disk brakes and would be probably applying the same torque. you think 12 or 13 gauge?
15mm length difference between radial and 1x.
it shows 79.9mm with radial. bit different than what this shows https://spokelengthcalculator.com/
