When sizeing a breaker, measure the peak load you see in normal operation, then divide by 0.8
Also, I would definately measure the currents before trusting the sticker on the controller. A "30amp" controller in reality can be anywhere between 15amps to 60amps.
Some folks sell controllers that shows a label that makes it duck the 750w law, but really it's a much higher current controller. Or more often, they de-rate a controller to be 20amps to let them use cheap parts and not blow, but sell it as a 30amp to be more appealing to customers. Or, it could be smack-dab on 30amps, never know.
I would definately measure first before buying a breaker though.
Also, with DC, a breaker rated at perhaps 50amps at 12v will be lucky to last 1 trip cycle at at 48v or higher. It should trip fine, but it will take too long in breaking the arc, and likely will have high resistance when reset.
