With regard to efficiency and performance, the mainstream automakers have been building vehicles almost as good as the VLC, even though their design principles follow the antiquated and still popular 3-box model.
The catch is that they never sold them to the public, even when the public wanted them. They made some prototypes demonstrating their technical capabilities, then let the accountants and stylists take over the engineering with regard to the cars sold to the public, if it makes into production in some form.
We've had the capability to triple today's fuel economy with minimal compromise, way back in the 1980s.
Renault unveiled their EVE concept car in 1980. The EVE was built on a Renault R18 chassis, used a supercharged 1.1 L inline 4-cylinder supercharged diesel engine, and had a 0.239 drag coefficient. This engine output a maximum of 50 horsepower. The curb weight of the vehicle was 1,900 lbs. The combination of these traits allowed it to achieve 70 mpg combined fuel economy.
Expanding upon the previous concept, the Renault EVE+ concept car was revealed to the public in 1983. It used the same 50 horsepower diesel engine as the EVE, but had reduced the curb weight to 1,880 lbs, had reduced the drag coefficient to 0.225, and achieved 63 mpg city, 81 mpg highway.
While the diesel Renault EVE concept cars were being developed and tested, Renault was also working on their gasoline powered Vesta concept cars. The Renault Vesta was revealed to the motoring public in 1981. It had a weight of 1130 lbs, a 0.25 drag coefficient, and a top speed of 75 mph. The Vesta's fuel economy is 78 mpg.
Renault's next generation of their Vesta concept car had reduced weight and reduced aerodynamic drag, which improved fuel economy and top speed. The 1987 Renault Vesta II weighed only 1,047 lbs, had a 0.186 drag coefficient, a 27 horsepower engine, and was able to return 78 mpg city, 107 mpg highway. Its top speed was over 80 mph.
Not wanting to be outdone by Renault, Peugeot and Citroen began the ECO 2000 program. The 1981 Citroen SA103 was able to obtain 65 mpg, thanks to a 0.27 drag coefficient, 948 lb curb weight, and a rear-mounted 700cc 2-cylinder gasoline engine.
The 1983 Citroen SA117 showed a remarkable improvement over its predecessor due to a drag coefficient of 0.21, front mounted engine with a front wheel drive configuration, and a curb weight of only 932 lbs; these improvements resulted in a fuel economy of 79 mpg. The SL117 used the same engine as the SA103.
The 1982 Citroen SA109 used an upgraded 3-cylinder gasoline engine with the displacement increased to 750cc. The car weighed in at 1,058 lbs and had a drag coefficient of 0.321, giving a fuel economy of 67 mpg.
The 1984 Citroen SL110 was the first of the ECO 2000 vehicles revealed to the public. It made use of the SA109's 35 horsepower engine, which allowed a top speed of 88 mph. The fuel economy was 76 mpg combined, and 112 mpg at a steady 55 mph. This was achievable due to a low drag coefficient of 0.22 and 992 lb curb weight.
Peugeot also revealed its ECO 2000 concept car. With a drag coefficient of 0.21, 990 lb curb weight, and a 28 horsepower 2-cylinder gasoline engine, the Peugeot ECO 2000 returned 70 mpg city and 77 mpg highway.
An effort by Peugeot from 1982 were its VERA and VERA+ concept cars. Unlike the ECO 2000, these cars used 50 horsepower turbo diesel engines. The VERA+ had a 0.22 drag coefficient, 1,740 lbs curb weight, and achieved 55 mpg city, 87 mpg highway. The VERA+ also had performance comparable to the commercially available cars of its time, with 0-60 mph acceleration in 13.2 seconds and a top speed of 100 mph.
The 1981 Volkswagen Auto 2000 obtained 63 mpg city, 71 mpg highway, boasting a 0.25 drag coefficient, 53 horsepower diesel engine, and 1,716 lb curb weight.
Volkswagen's E80 diesel concept obtained even better fuel economy. Using a 51 horsepower supercharged 3-cylinder turbo diesel, the 1,540 lb Volkswagen E80 managed to obtain 74 mpg city and 99 mpg highway. It had a 0.35 drag coefficient.
In 1983, Volvo was able to demonstrate that fuel efficiency, safety, practicality, and performance were possible in a production-ready car with its LCP 2000. First and foremost, the car was designed for maximum safety; not only were the rear seats facing backward so that the center of the car could be designed for added structural rigidity and increased resistance against side impacts, but the car passed a head-on passenger-crash survival test at 35 mph, which exceeded the 30 mph requirement of the time. Performance was excellent for the time period and is still comparable to the entry level compact cars sold today, with 0-60 mph acceleration in 11 seconds and a top speed of 110 mph. Fuel economy was rated at 56 mpg city, 81 mpg highway, and 65 mpg combined. The car weighed a mere 1,555 lbs, had a 0.25 drag coefficient, and was powered by an 88 horsepower diesel engine. In volume of 20,000 cars per year, the cost penalty would have been effectively zero over comparable production cars for the period.
The 1982 GM TPC managed an astounding 61 mpg city, 74 mpg highway, using a lightweight aluminum body and engine; the curb weight was light at only 1,040 lbs, but the drag coefficient was an unremarkable 0.31. It used a 3-cylinder gasoline engine which only produced 38 horsepower.
In 1983, GM had upgraded its Lean Machine concept to obtain up to 200 mpg. To obtain such stunning efficiency, the vehicle needed to be as light and as aerodynamic as possible, weighing in at only 400 lbs and having a 0.15 drag coefficient. A 38 horsepower, 2-cylinder Otto cycle engine was able to rocket this machine from 0-60 mph in 6.8 seconds. Top speed was 80 mph.
Not wishing to be surpassed by the American and European automakers, Toyota began experimenting with its AXV series of concept cars.
The first Toyota AXV was powered by a 56 horsepower direct-injection diesel engine; this combined with a low curb weighed of under 1,500 lbs, a 0.26 drag coefficient, and a continuously variable transmission allowed the AXV to achieve 89 mpg city, 110 mpg highway, and 98 mpg combined.
Later incarnations of the AVX were not as fuel-efficient.
In 1991, Honda developed the EPX, a tandem two-seater concept car that used a 1 liter lean-burn engine, weighed under 1,400 lbs, and supposedly returned a fuel economy of 100 mpg. Currently, the car isn't in running condition.
Continuing a trend of fuel efficient concepts, the Honda JVX was unveiled in 1997; using a 1.0 liter, 3-cylinder gasoline engine and an electric motor with a capacitor bank, it was able to manage 67 mpg. Designed for safety, the passenger and driver seat belts are configured to inflate during a crash to help protect the occupants from injuries normally caused by seat belts.
And if gasoline or diesel isn't your thing, ALL of the above would have made for some extremely efficient donor chassis for EV conversion. We're talking cars that could consistently consume < 150 Wh/mi here...
Sources, for any skeptics:
-Renault Club. (2007). 1981 – Renault EVE. Retrieved June 27, 2007, from http://www.renaultclub.cz/1981_-_renault_eve.html
-Saxon, D. (1988). Technology and the American Economic Transition: Choices for the Future. U.S. Congress, Office of Technology Assessment, OTA-TET-283. Washington, DC: U.S. Government Printing Office.
-Philippe B. de l'Arc – A coeur vaillant, rien d'impossible. (2007). Aerodynamic Drag, Data for airfoils, Wings, Aircraft, Automobiles. Retrieved June 27, 2007, from pboursin.club.fr/res/aero.xls
-Parliament, UK. (2003, October). Memorandum by Stephen Plowden: Cars of the Future. Retrieved June 27, 2007, from http://www.publications.parliament.uk/pa/cm200304/cmselect/cmtran/319/319we06.htm
-Greenpeace. (2005, December 5). SmILE – Showing Car Companies How it's Done. Retrieved June 27, 2007, from http://archive.greenpeace.org/climate/industry/reports/smile.html
-Bleviss, D. (1988). The New Oil Crisis and Fuel Economy Technologies. New York: Quorum Books
-Forza Mondo. (2006, August 20). L'Auto del futuro. Retrieved June 27, 2007 from http://forzamondo.blogspot.com/2006/08/lauto-del-futuro.html
-Histomobile. (2004, October 15). Citroen Eco 2000 concept. Retrieved June 27, 2007 from http://www.histomobile.com/1/Citroen/1984/Eco_2000.htm?lan=1
-Generation Futures. (2006, March 26). Mon avis d'utilisateur sur la Citroën AX 14 TRD, ainsi que son coût kilométrique réel. Retrieved June 27, 2007 from http://generationsfutures.chez-alice.fr/velo/citroen_ax_diesel.htm
-Audi Sport Collection. (2007, June 29). Magazine : L'Audi 2000 face à ses rivales. Retrieved June 29, 2007 from http://www.audisportcollection.com/ASC2006/392.php
-Baldwin, J. (1990, Fall). Eco-Cars – the Volvo LCP 2000 research auto. Whole Earth Review. Retrieved June 29, 2007 from http://findarticles.com/p/articles/mi_m1510/is_n68/ai_8897890/pg_1
-Lovins, A. (1990, December). Make Fuel Efficiency Our Gulf Strategy. New York Times. Retrieved August 6, 2007, from http://www.rmi.org/images/PDFs/Security/S90-26_MakeFuelEffGulf.pdf
-Timion, M. (2007, June 14) 100 Miles Per Gallon? That's so “1992”. Retrieved August 6, 2007, from http://www.100mpgplus.com/articles/magazine/article_unocal.html
-EPCOT Center (1983). The Lean Machine. Retrieved August 6, 2007, from maxmatic Web Site: http://www.maxmatic.com/ttw_leanmachine.htm
-maxmatic (2004, July 23) TTW – Tilting Three Wheelers: GM Lean Machine. Retrieved August 6, 2007, from http://www.maxmatic.com/ttw_leanmachine.htm
-National Research Council. (1992). Automotive Fuel Economy: How Far Should We Go? Washington D.C.: National Academy Press
-Auto Concept Reviews. (2007, April 16). Honda EPX Concept 1991. Retrieved August 6, 2007, from http://www.autoconcept-reviews.com/cars_reviews/honda/Honda_EPX_Concept_1991/cars_reviews_honda_epx_concept.html
-Insightman. (2000, July 22). The Honda JV-X Concept Car Introduces the IMA Hybrid Power-Train. Retrieved August 6, 2007 from http://www.insightman.com/J-VX/J-VX.htm
