waynebergman
PARAJARED ASKED...........
1) does the display that comes with it limit the amperage? (keep me from accidentally sending 100 amps down the thing)
2) how does the thing do on ridiculous steep hills, hills so steep your tires can barely hang on? (I don't care about top speed, I need torque)
3) stock chainring vs bling ring?
4) that plastic gear is going to wear out, how easy is it to swap? Can I buy a replacement gear?
5) waterproof? how stupid can I get with the water?
Hey parajared......
1.Amperage is only set from controller. default is 25 amps and 30 is better with a program cable
2.With gearing set to one to one you can outclimb your grip with tires and not even heat her up.
3. Go with one to one gearing if you want single track fun.....anything else is not full torque out of this motor
4. Lots of info out there on this one. I dont know but LUna sells them for cheap
5. from what I read things are pretty water resistant.
Hey parajared......
