Hello, forum, I'll try to be brief but will include all the info I can. Thanks in advanced.
Issue
- I've got a 10s2p Lithium Ion battery that when plugged in to the charger the charger indicates that the battery is charged even though it is not.
- I accidentally got it wet so there is some rust (or corrosion?) on some terminals, but the BMS doesn't look like it got wet.
Photos
I got it charging once but it only went to about 36v and stopped charging
This is what I did to get it charging:
- At this point, the battery was about 35v give or take 0.1-0.2v
- Charged via the discharge plug for a few minutes, then unplugged
- Unplugged the balance lead for about 30 mins, then plugged back in
- Plugged the charger to the charge plug and it started charging
- Once it got to 36v it stopped charging
- Now it's back to square one, where it won't charge. I tried discharging until 35v again, and it still won't charge that either.
Tests I've performed; and its current state
- Charging via the discharge plug: This works. The charger indicates it charges, and it does actually charge.
- Resetting the BMS by unplugging balance plug and putting it back in. I left it off overnight. This doesn't help anymore.
- Voltage reading from discharge plug: 35.4v
- Voltage reading from charge plug: 35.1v
- Voltage reading from individual cells: 3.55v except one where it was 3.56v
- Based on this video https://youtu.be/6i8i6h1LkBw?t=435 which notes that I shouldn't have any voltage between the negative terminals on the BMS (C-, P- and B-), I can confirm that I do. I get about 0.01v -- I'll need to recheck this to confirm what it is exactly, but I can say that it's not 0.
What I'm after
- Any help further troubleshooting?
- If it's the BMS, any help in buying a correct replacement
Other misc info:
- While testing voltage for individual cells, I don't know what happened, but it began smoking at the positive terminal. Looks like the smoke came from the casing of the battery being burnt. I still successfully tested that battery and was the same as the rest.
- It's a battery for an electric skateboard
Issue
Photos
What I'm after
Other misc info:
