Hi all,
I would like to ask a few questions to people who may already have one or both of the above mentioned kits. I have already decided that a bafang crank drive is right for me, just can't decide which.
I ride a mountain bike mostly on local trail, some XC (~30 miles or so). I want to enhance my ride distance, speed and help on hills, but will still pedal all of the time, therefore only interested in pedal assist.
I test rode a Haibike Bosch unit which I thought was pretty good, but too pricey.
Having extra power when I need it is good however I see the following pros/cons of the BBS02:
1. More weight due to 48v battery and heavier motor
2. Possibly less efficient if used on low settings for a small assist level. Will the BBS02 have significantly less range?
3. If I did go BBS02, am I right in thinking the 750w version is the same motor as the 500w therefore buying the 500w is pointless as you could just set the 750w on a lower setting to be equivalent?
4. The obvious pro of more power and therefore more fun!
Has anyone rode both that can comment?
