Wheazel
:lol:Punx0r said:Phase 1: Recommended Ultrafire-esque cells
Phase 2: Vigorously defend decision to recommend Ultrafire-esque cells
Phase 3: ?
Phase 4 Profit!
Phase 3: ?
Phase 4 Profit!
tomjasz said:Overclocker said:[
these came out to about $1 per cell. got them via amazon. genuine 3M portable projector batteries. chinese 18650 from a company i've never heard of, Amperex. i guess 3M wouldn't risk their reputation on explosive cells. haven't heard of any recalls
and they come welded w/ nickel tabs so a noob could easily wire them up
They made a mediocre pack on the cheap, but their age will affect their service. They weren't reject cells, the product was discontinued. A market failure.
parabellum said:What is the capacity and IR of those cells?Overclocker said:i'm sure i got graphs of this cell somewhere, which isn't very pretty (IR is a bit high)
now take your condescending tone and gtfo
redilast said:Panasonic NCR18650BE is the best value in my opinion. Great price per watt hour, good balance between high drain and high capacity (10A max current).
Dauntless said:
I can only say so far so good, but I haven't had them long. The price has gone up since I got mine for 4x $7.99, it's $9.75 for the set now. 15 ratings on Amazon, 10 at 5, 4 at 4 and a 3. The down votes are just about their device problems, actually.
https://www.amazon.com/gp/product/B01CNV27K4/ref=od_aui_detailpages00?ie=UTF8&psc=1
Punx0r said:Is this a joke?
eric1565 said:Buy used tesla cells. it is the cheapest way to get QUALITY 18650BE's
Buy from someone who has sold a fair amount so you have a good idea you are getting what they are saying you are getting.
If you are making your own pack I recommend not to solder them, and if you are going to solder them get a HIGH powered iron so you can do it quick. You don't want to heat the "jelly roll" up too much. If you use a low powered soldering iron, all you will do is heat up the whole cell. You need to hit it fast and hot to get the solder to melt and get a good bond.
Welding is the right way..
Eric
Those are usually removed from wrecked vehicles. Many of them have under 100 cycles in conservative DOD region and good for thousands more. Responsible seller will know how many cycles those had and will check and share IR and capacity average before you buy. Then, if those cells sneaked in to a Tesla, you can be sure they are A+ grade. :wink:msebold said:Why would you want to buy used cells? If they're being removed from use in a Tesla vehicle doesn't that mean they are near the end of their useful life? Why do you find these to be a good buy?
parabellum said:Those are usually removed from wrecked vehicles. Many of them have under 100 cycles in conservative DOD region and good for thousands more. Responsible seller will know how many cycles those had and will check and share IR and capacity average before you buy. Then, if those cells sneaked in to a Tesla, you can be sure they are A+ grade. :wink:msebold said:Why would you want to buy used cells? If they're being removed from use in a Tesla vehicle doesn't that mean they are near the end of their useful life? Why do you find these to be a good buy?
https://endless-sphere.com/forums/viewtopic.php?f=9&t=67661msebold said:Thanks! Got a link, or know a place where I might keep an eye out for these?
msebold said:Lurkin said:The reality is, there is no 'best cell' or 'best cell for the buck' until you qualify what it is you are using it for.
Parameters include cost, safety, knowledge, user friendliness, personal preference, size/shape, quality, DIY/vendor assembled, required discharge rate, capacity, compatibility, longevity expectations to name a few...
Lots of variable here. As you know, I am inquiring about cost versus output of individual cells. You know of any particular 18650 cells that have safety issues, that are not user friendly, that vary in size or shape, or that require assembly? Not really sure what you're trying to relate here Lurkin.
msebold said:So what's your experience? . . . .performance claims seem dubious.
Lurkin said:msebold said:Lurkin said:The decision you are trying to make is more complex than comparing cost to output. Choose your components (hub/middrive, controller and thus output wattage required) and work backwards, the cells capacity and discharge requirements should be the last step in the planning process.
Ergo, the decision is based on what you need, not whats available.
For instance, buy low capacity, high discharge cells then discharge them slowly - whats the point paying for high discharge cells?
wattage required > packs ability to discharge - are you going to roast the pack?
Living at a farm with a paddock for charging and storing cells - why use 18650s? why not consider lipo?
limited space on the bike for a battery - indicates high capacity cells.. but what discharge rate is required per cell?
do you have the ability to assemble a 18650 pack safely?
do you have the knowledge to charge and deal with lipo?
does the battery have the capacity loss characteristics which are acceptable to you?
None of these decisions have discussed price at all. Its almost irrelevant right up until you nail down what battery actually suits your needs - chemistry, discharge rate, capacity, size, pack assembly..... I think you'll find if you do a thorough job of cell choice, it will limit the cells acceptable to you and then its just a matter of finding them cheaply.
Dauntless said:So the entrance of the park was completely black in my camera without the maybe 5w light.
Killer-B said:Just thought Id pop in and say Hi. Ive built many of my own 18650 pack. Latest is 24s 6p.. id be happy to help others in my area.Ive got a good cell hookup and the welder Guelph Ontario Canada
Thanks Eric. I plan to get a battery spot welder. I am interested in the used Tesla 18650 BE cells. Why would you want to buy used cells? If they're being removed from use in a Tesla vehicle doesn't that mean they are near the end of their useful life? Why do you find these to be a good buy?
eric1565 said:I have a number of 4s7p tesla packs and they are great. I can burst 21 amps per cell(same as tesla) and they get slightly warm. I can pull 10 amps continuous no problem.
Dauntless said:I don't expect it to be the 5.8. I don't really have a way to run a capacity test. Lasts for hours in the flashlights, they might be 5-7w.
Eric, I'm very interested in the Tesla packs. Any way you might tell me where I might get some of these?
eric1565 said:I made the packs myself. I used a welder made by riba. I bought the cells from okashira.
msebold said:eric1565 said:I made the packs myself. I used a welder made by riba. I bought the cells from okashira.
I'm sorry. I'm trying to make sure I understand what Okashira sells (if he still sells them). Did you receive the individual 18650 Tesla cells, or did you receive Tesla modules (or partial modules) that you were working with?
Sometimes even cars.cal3thousand said:He gets full modules
