Xrain
I just came across this battery company in my Racecar Engineering Magazine from this month.
http://www.braillebattery.com/index.php/
Their batteries are very pretty looking, all carbon fiber cases, great discharge rate (~50C continuous. ~55 Burst) As well as 2500 cycles at 80% DoD
But they seem to be very, very expensive. These batteries are used in formula 1, and other high end racing events as starting batteries.
Any thoughts on what kind of cells are in it? I'm guessing LiFePO4 because of the cycle life, But the discharge rates seem awfully high having a continuous rating even higher than A123's. (this was the battery I was looking at
http://www.braillebattery.com/index.php/batteries/490l/#)
The cycle life/discharge rate of the cells seems to vary depending on what model of battery...
They also seem to have invented their very own capacity rating system called "Lithium Amp-Hours" (LAH), But they generally show the standard Ah rating as well.
Thoughts?
edit: looking at the discharge rate they could be 26650 A123's, But the nominal voltage, and capacity doesn't quite add up. Granted I suppose they could be undervaluing their battery but that doesn't seem quite likely.
Thoughts?
