Drynk
Hi, I want to build a bike to commute 13 miles back and forth mostly flat but on rough gravel not much potholes/washboard more loose unpacked or packed snow/ice. I like to build things myself and get the best bang for my buck. I already got a few good condition solid and heavy 90s no suspension mountain bikes and managed to find locally at reasonable price not selling nos 5 or so years old power tool batteries containing samsung inr21700-30t which still got their full capacities (at least the few i tested). I think it would be nice to put 3 inch semi slick tires on it and add chains for the winter, thought it might soften up the ride a bit, probably not necessary, the stock 2''agressive mtb tires should do the job and i'll save a bit plus some custom fitting work. I'd be happy if I can maintain 30 mph. I was thinking of going dual direct drive hub motor for more traction and backup if one fail. I like silent things and ebrake would be nice too. I think I'll need more or less 1kwh to do the run I've been doing research for the last month or so and I am as much confused as I began. Do i go awd fwd or rwd? If awd do i use 2 direct drive or 1 direct drive and 1 geared? Could i use 2 smallish 500w dd and over volt them a bit or should I just use the larger(s) 10''ish since my bike is gonna be heavy anyway? How much power do i really need?
