An error 30 suddenly occurred on my BBSHD 1000w right after I connected a new brake sensor that has a 2-pin connector, lacking a ground pin, and then activated the sensor. Normally, the brake sensor requires a 3-pin connector, including a ground pin.
According the facts, So I think it's definitely NOT the external("wiring or physical") problem. This is because the error appeared "immediately" after I press the sensor switch for testing( but with the wrong connection with wrong +/- pin ). Not something from "broken or disconnected" as the condition of my bike was always best.
So I'm asking if anyone has experienced a similar situation. It seems to have been caused by some kind of "electronic" shock.
is it possible that the "electronic" damage was happened inside of controller or wherever?
then i would consider to replace my controller ...
i think this community is only helper for my case as it's hard to search same case in youtube or google... I believe the strength of crowd knowledge please thank you.,
Thank you engineers.
- Fact: 0% battery displayed after restart the bike
- Confirmed: Batter itself has no problem. (i have another same bike)
- Fact: I was trying to replace my brake(sensor) so natually new brake sensor connection was happened. (2pin - not standard)
- Fact: the error appeared "immediately" after I press the sensor switch for testing(but with the wrong connection with wrong +/- pin
- Fact: My bike was as always normal status. of course worked well right before "the action"
- Confirmed: Cable connectivity has no problem (never touched since my Bike worked right before the trouble.)
- Confirmed: Display(Computer) has no software side problem (if I connect my another same bike's display, it displays same (error 30))
