Awesome build! On Keplers super-commuter, he machined a housing out of high-density-poly-ethylene (HDPE), and it cut like butter, very easy. I wasn't up to date on the best candidates for a power board, so I immediately noticed the D-shaped axle on this model of truck...I would definitely spec these if I was making a similar project.
If the drive wheel is starting to slip when you are on the steepest incline, you need 2WD, so maybe try a second system on the other axle. If it has enough traction, but it's starting to bog down then you need more power, I'd go to more voltage. I wouldn't go faster than 20-MPH, so if you go to 10S / 37V, spec a motor with a 30% lower Kv, somewhere around 180-Kv. If you double the volts to 44V, then you can cut the Kv in half (I know 63mm motors can be found in a 149-Kv, I wouldn't go smaller than 63mm diameter).
For more speed without changing the volts or Kv, I'd make the drive pulley larger to keep as many belt-teeth engaged as physically possible (rather than making the wheel-pulley smaller).
Well done. The water-jetting can be much cheaper per part if you order 5-10, so consider making up several kits and selling just the ones you don't need. This would also let you try 2WD, then sell it then you'd be back at one-wheel-drive. You could easily sell 4 kits to pay for the 5th.
I think my board maxes out around a 10-15% grade. But I only have 6S, so I don't know what a better power system would be able to do
