E-HP said:neptronix said:Flat ground on high voltage will tell you a lot more about continuous power handling.
The problem is that the OP has specified the voltage as 52V, so it seems like that's a fixed input as far as the question goes. Then on flat ground, the motor will never pull 2000W unless under acceleration, based on the simulator.
TuomasK said:Situation at 12mph where motor pulls just under 100 phase amps at ~20V (2000w) or with poor efficiency of 68.5%. Motor converts this 2001w to output power of 1371W.
https://ebikes.ca/tools/simulator.html?motor=GMAC8T&batt=cust_58_0.050_21&wheel=28i&frame=mountain&mass=100&hp=0&axis=mph&cont=cust_40_100_0.001_V&cont_b=cust_40_100_0.001_V&motor_b=GMAC8T&batt_b=cust_58_0.100_18&wheel_b=28i&frame_b=mountain&mass_b=100&hp_b=0
Situation at 36mph where motor pulls just under 44 phase amps against back emf voltage (2000w) the efficiency is now 86.3%. Motor converts this 2006w to output power of 1732W.
E-HP said:TuomasK said:Situation at 12mph where motor pulls just under 100 phase amps at ~20V (2000w) or with poor efficiency of 68.5%. Motor converts this 2001w to output power of 1371W.
Idea. Instead of including a link to the same graph over and over, you could set the parameters then take a screen shot and post that.
OK, at least I can see what you're doing. The simplifying assumption is that the controller has no losses, so the battery watts equals the motor watts, plus the heating watts (the 2000 battery watts equals the 1300 motor watts, plus 700 heating watts, in the first example). From what I see, this still only represents the power and efficiency when the bike is accelerating, not continuous. So, what is the continuous scenario where the efficiency would be so low? If you are only talking about under acceleration, then how many hard accelerations could you have before the motor melts?TuomasK said:Ok. Maybe I'll start with screen shots as nobody else bothers.
E-HP said:OK, at least I can see what you're doing. The simplifying assumption is that the controller has no losses, so the battery watts equals the motor watts, plus the heating watts (the 2000 battery watts equals the 1300 motor watts, plus 700 heating watts, in the first example). From what I see, this still only represents the power and efficiency when the bike is accelerating, not continuous. So, what is the continuous scenario where the efficiency would be so low? If you are only talking about under acceleration, then how many hard accelerations could you have before the motor melts?TuomasK said:Ok. Maybe I'll start with screen shots as nobody else bothers.
