Chaos scooter.
Mr y
10 µW
Newcastle upon Tyne.
Hello can anybody help! I own a chaos 48v/1000w scooter, hub drive the latest model. I have noticed that it is identical to the 48v/1600w scooter.the controler
Battery and rear drive hub wheel all share the same part numbers as the chaos 1600w version, my 1000w scooter is fitted with a 1600w controller(factory fitted)
How can I make my scooter do the same top speed. Thanks.
Are you locked to 20mph? Seems like this may be a limitation within the controller. Usually, you can access the settings in the display to remove that limit. I have a 36v scooter and the top speed is 20mph. I would think that you should get closer to 28MPH, with 48v.
