It definitely helps to not have to stack stuff; if you get eggs and heavy but bruisable/crushable veggies, bread, etc., all at the same time you might not be able to pack them in a way that will not end up with something getting squished in there, especially with potholes and whatnot.
For instance, when I get groceries I usually get a month or two's worth at a time. Using SB Cruiser I can stack several styrofoam coolers on the cargo deck, or put them inside the lockable kennel if I am gonna have to go to several stores and leave stuff on the trike (common).
I can provide separate coolers for stuff likely to bounce around and break other stuff, or even pack towels or other padding in there for fragile things, or just put styrofoam dividers in; can even keep hot and cold and room temperature stuff all in separate areas or coolers, etc.
I used to use backpacks and bags when I was on a regular bike, back in my pedal days, and quickly migrated to baskets front and rear so I could keep different stuff in different baskets/bags. Once I started using trailers I went to coolers and boxes to carry with and it helped a lot.
When I went to ebikes I started again with baskets, went to a rack with a metal box on one side (lockable), then both sides, etc, etc, plus the trailer, and now I have the trike with it's cargo bed and overbed rack (and kennel if I need it), plus a multi-mode trailer.
But the boxes vs the bags, still works better with boxes unless you have a number of separate bags to put stuff in.
