Hi JRH and thanks for sharing your own real life experience on the matter here, it's nice to have feedback from people who have firsthand expertise of the pros and cons in an almost identical application.
johnrobholmes said:
The big hurdle will be the wide temperature variation, but I think the two product strategy will work wonderfully.
Well we got our first trial experience in last week after the machined heatsink parts came back from hard coat anodizing. It turns out that the epoxy rubber product which I thought would make a great first coat for CTE isolation was almost impossible to keep on the raw board in any kind of thickness. Even though it is quite viscous and goopy, when sitting it would slowly drain off until just the thinnest of films was remaining so I ended up putting the controller in a lathe chuck at 100rpm while the epoxy cured in an attempt to keep the film distributed. But even then it was still pretty thin in some sections, and almost for sure we'd want to switch to another product for this step:
You can see the small square of acrylic glued over the surface mount LED on the bottom right of the PCB.
The 2nd stage pour though worked out just as hoped. I needed a bit of sideways clamping pressure on the silicone mold to prevent leakage, but pouring in the resin from the top at the wire exit didn't cause problems.
And after popping out it looks identical to the 3D printed prototype, including the hexagonal fill marks on the top plane and all the other small visual defects of the model. And the LED shines through great.
I had this installed on my bike and on the way home last night got hit by a surprise rainstorm, and I've never been so gleeful to watched my motor controller get splattered with water!
For effectiveness, I would suggest an epoxy or epoxy over a silicon. Silicons will routinely separate from the wire jackets and allow water to wick in. A base silicon layer would give a great CTE cushion, and an epoxy outer will give more durability and protection from delamination from the wire jacket. However, I don't know how well epoxy will hold to silicon as I have never tried it.
From my experience here's pretty much zero bonding between cured silicone and anything other than silicone (though I see a patent on the topic here
http://www.google.com/patents/US3519465.) But I'm not sure if a bonding between the two layers is all that important. They're more or less mechanically entrapped in each other and would water get between the two it's not exposing the circuitry or wiring.
The best strategy may indeed be a softer epoxy conformal with a harder epoxy outer. At any rate, a two part epoxy will cure much better in a mold than a silicon that requires offgassing. It could take days for offgassing to complete, maybe even a week unless you pulled a vacuum on it too. Have a vac chamber that will fit 50 controllers? :lol:
Trying to avoid all usage of both our pressure pot and vacuum chambers in this process
We were at the
DEX expo today and had a great discussion with a local distributor of electrical resins and adhesives about this project. He had some good things to day about some marine grade urethane rubber potting compounds, which we'll likely try as well since then it could be a single stage pour. Tg is -16oC and durometer at ~80A is firm enough for the finished part yet soft enough not to transfer much thermal stress. I'd generally ruled out PU over epoxy for long term water and UV resistance, but if it's meant for marine...
Justin, if you can get failure rates below 1% you will be my hero!
Well it would mostly be ASI who'd deserve the credit for that since they did all the electronics design, we're just trying to package it nicely for end users. But yeah, <1% is the goal. Realistically, 2-3% would still be pretty decent, that's about what we have with the Cycle Analyst and it's manageable although in those cases it's almost always an easy repair. With potted that won't be an option.
