What happens when you click Reset under Status? Does the fault immediately recur? I have this vague memory that the first time I powered up my unit, some fault was present, but after I hit Reset everything proceeded normally. This might clear the warning as well.
Thanks for the response. When I click Reset Status, and push read button from display only frame, error persists.
I'm not sure what the speed signal is measuring, but 6 pulses per revolution sounds really low, especially for a geared hub. Be sure you're turning the wheel backward, otherwise the motor will freewheel. I'd guess that it's measuring transitions on one of the hall sensors, so in 1 revolution of the wheel you should see (pole pairs)*(gear ratio) pulses. If you don't know the gear ratio it's fine to enter the total pulses per revolution for pole pairs and 1 for the gear ratio, and the rated wheel rpm for the rated motor speed.
This data comes from other people at this forum and whirlpool BH bikes thread. It's a signal from the internal speed sensor. We have been trying to hack limitation and played with it. BH Bikes use Infineon controllers, so I think it won't suppose a problem in the future. But... at this moment I'm trying to handle wiring/config issues.
When I turn on battery power red flash and give me different codes: 3,2,5 and 8 :?
