rockypro1 said:Hi all,
Looking for help about my e-bike.
On my controller it says 15 amp max, dose this mean that I can only use a battery that is rated 15 amps or less. And if I use a higher amp battery will it damage the controller.
Thanks.
e-beach said:Depends. How many volts is your existing battery?
rockypro1 said:e-beach said:Depends. How many volts is your existing battery?
Hi Mr. e-beach,
I don't have any battery of yet. I'm looking for help in what battery to get for my e-bike build.
Its a 48volt 1000 watt, controller says max 15amp.
rockypro1 said:Guys would this battery work on my controller for now?. I can always upgrade the controller in the future.
https://www.amazon.co.uk/dp/B07B2819YT/?coliid=I31KV835YTP9MO&colid=2KY1AMSNHVM76&psc=0&ref_=lv_ov_lig_dp_it
or
https://www.amazon.co.uk/dp/B0745J88J8/?coliid=I1KCDD61A903WH&colid=2KY1AMSNHVM76&psc=0&ref_=lv_ov_lig_dp_it
or this one
https://www.amazon.co.uk/dp/B079GZ3G2R/?coliid=IM8AXAQFO2IHO&colid=2KY1AMSNHVM76&psc=0&ref_=lv_ov_lig_dp_it
I was not sure about going higher in amps with the battery.molybdenum said:rockypro1 said:e-beach said:Depends. How many volts is your existing battery?
Hi Mr. e-beach,
If your controller is rated max 15 amps, you need to get a battery that will push at least 15 amps without being overly stressed or your battery will die an early death. It doesn't matter if your battery is rated much higher say 100 + amps. The controller will only take what it needs.
Buy from a reputable dealer with quality Panasonic or Samsung cells.
Alan B said:A good plan for the future would be to get a battery that could supply a larger current for the controller you would really like to have, not just the one you have now. Just in case you upgrade the controller. Upgrading the battery is not something you want to do later. 30A capable batteries are not uncommon. Your motor can handle that. So a controller upgrade might be in your future, long before the battery is worn out.
Would there be much difference between 35a and 40a continuous discharge. As I think there is a 100.00 euro give or take in the price.e-beach said:rockypro1 said:Guys would this battery work on my controller for now?. I can always upgrade the controller in the future.
or
or this one
Two of these batteries rate at 35a or 40a maximum continuous discharge. That is what you want to know. The third doesn't seem to mention the contentious discharge rating. I tend to stay from sellers who can't even post the basic information.
Your controller will deliver 15a continuous to the motor under startup, long and/or steep hills and any other condition that makes the motor work. A 15a controller is pretty small around here. If your motor is really 48v at 1000w I would recommend spending a little more money for at least a 30a controller.
You don't have to go fast all the time, but it is nice to have when you need it.
rockypro1 said:Hi guys,
Sorry to drive ya's mad again about a battery for my ebike. But I am thinking about getting this one, what do you's think?
https://www.amazon.co.uk/Powerful-Triangle-Battery-Electric-Lithium/dp/B01L53G93W/ref=sr_1_5?ie=UTF8&qid=1523399335&sr=8-5&keywords=ebike+battery+48v
e-beach said:rockypro1 said:Hi guys,
That one seems a little off to me. 26Ah for a battery that size and that price seems too good to be true. If the manufacture will give you guaranteed proof and documentation that the battery is 48v and 26ah, then go with it. Contact them and see if they respond. If they will not give you proper proof, go somewhere else to get your battery.
http://www.ebikes.ca/
https://em3ev.com/
http://www.pingbattery.com/
or build your own with cells from https://eu.nkon.nl/
BTW. lithium cells are the way to go, however, if they are prohibitively expensive in your country, go retro and use motorcycle batteries. They are lead, heavy, will only last 18 - 24 months, but they are affordable.
There is also RC lipo. They are cheaper then other lithium, and have a higher energy density and discharge. They are, however the kind that will catch fire if not handled properly. Treat them right, you will be fine. Treat them wrong, up goes the house.
https://hobbyking.com/en_us/batteries/lipo-batteries-all-brands.html?___store=en_us
Hi,999zip999 said:Don't fall for Tesla like cells. Get a certain brand and a certain part number on the cells that way you know if they're going to deliver 5amps 15 amp per cell or a 25 amp per cell
