__mike
Hi guys,
My Setup is as follows:
Leaf 35mm 5t / em3ev Infineon 9fet 4011 / 16s lipo / 26" wheel/cav3
Am happy with this setup for now but the speed is around 15km/hr more than I use/need. Good to have it there 'if' I need it but am curious if there is any benefit in removing. I don't want to change out my pack (8s2p2s) and I know I can restrict speed with the cav3.
If I change the default speed setting with the controller back to 75% I'll be at ~48km/hr which is plenty. The pulses (??) that control the speed will be less , amps\input voltage remains the same, my throttle control range should still be 100% of this 75% speed / pulse range. My Max speed capability will be less which will the be closer to my average riding speed. So effectively my controller will be operating the motor closer to its maximum speed and will run cooler? If I'm full throttle at this speed on flat Tarmac / neutral wind I'll be drawing say an estimate 1500watts instead of 2000watts/still accelerating. I know I can use partial throttle for the same result but it's just easier to hold full throttle over rough ground. Does this make any sense / truth? Or no benefit leave it alone ?
I know riding around on a lot of partial throttle gets the controller quite warm which got me thinking...... Maybe too much
Mike
Mike
