pendragon8000
Hey y'all...
Just wanted to drop my experience of swapping controllers to sensorles mode ebikes.ca 40amp controller.
I tuned in the throttle max and min, shunt R and corrected my watt/amp/ramp values and its very smooth with quite good power modulation/restriction.
Although when its low power the increments are fairly noticeable but not too bad considering the difference is about 100watt jumps around 500-700watts. I did a conservative on the throttle in 1.2kw limit ride today using 500wh.tuned it in more and more throughout the ride.
IMO
sensorless with the cav3 is great if you CBF fixing halls/hall wires or don't know how.
Only issue is I need to connect a speed wire.
IMO
