Hello, I am running a Bafang BBS02 48/750. I have been using a 500C display which would lose power and stop the motor from running. It seemed like a loose wire because I could wiggle it and see the display shut down. Usually I could either disconnect a plug (display or harness) re connect and it would flash right up. When it would no longer turn back on I swapped my 965 display in. I had basically the same problem. I also swapped out the harness for a new one and replaced the controller as well. 500C would not power on but 965C does. If I power off the 965 it will not start up unless I do the plug thing, or switch my battery off and on. The thing is that now the bike functions without the display being switched on, both PAS and throttle. Another thing I discovered is that if I spin the cranks backwards the motor will attempt to lurch forward. My next guess would be the motor core but I'd rather not drop the money on something that may not work. If anyone has any advice I be much obliged.
