rootshell
1 W
e-beach said:Sanding. Give it several coats, let it dry completely. Give a light sanding with a fine grit sandpaper to smooth it out. It will dull but will get shiny again when you give it a gloss coat. The gloss coat is where you will need the super fine sand paper to smooth it out while still polishing it to a glass like shine.
I tried this technique on my test pipe. Hit the paint with wet sanding 400-800-1000-1200-1500 and it did exactly what you said. Smoother but dull. Just hit it with some clear coat to see how it comes out, but it already looks better.
When you say several coats, Ive been wondering. Is it better to hit it completely within the 1 hour time frame, or after 48 hours as suggested on the can?
Should I bother sanding between coats of paint?
