I recieved my 'used like new'
4ah bat and charger. It came in almost dead @ 45v and took about 2hr to charge and balance from 3.2 cell avg to 4.15 cell avg.
I am testing on my 1kw hub. I soldered some 3/8 battery terminal connectors on an old jumper cable for the bike/battery connection. They simply push in place.
I pulled the 4 hidded face screws and 8 exposed side screws, and the entire assembly lifts right out. I didn't have a security bit but standard torx bit with a little slot ground in worked fine. I tested the 14 groups fully charged and they averaged 4.15 after the initial charge. The ribbon cable for bms function is pretty cool, and it's a tight little pack of lg cells.
I went for wot test ride today. Same road up and back down, 170ft elevation in 1.8 miles . . . I first noticed a sag below 3.5 cell avg after about 65% of the initial 3.6 miles of
wot with no pedalling. I continued a back and forth several times of about 200yds on a level alley with wot each time, finishing @
4.3 miles total. Resting voltage read 49v (~3.5/cell), and full draw sags the pack to ~ 3.2 cell avg.
So I'm quite happy with the 2p of cells. Although they get warm with this use I expect they'll give plenty of cycles for the money, and 1mi per AH is not bad at all for the draw I was pulling. I'm planning on selling this with my 1kw bike and kit for what I paid.
325$ for a 28mph 4mile/charge starter ebike is hard to beat!!!
(40$ bike/stuff, 210$ kit, 75$ battery/charger)
I would recommend to anyone that it would be best @ 1kw to get a second battery in parallel so the cells see less stress, but 1 pack appears sufficient for light use. And what ebike packs even come close in the warranty available??
