SlowCo
I think you'll be better off to aim at 30mph/50km/h if you want to keep the motor cool enough and not trip the BMS when needing to go uphill. You might even downtune the shunt in the controller to lower the amp draw.
SlowCo said:I think you'll be better off to aim at 30mph/50km/h if you want to keep the motor cool enough and not trip the BMS when needing to go uphill. You might even downtune the shunt in the controller to lower the amp draw.
Ah ok i understand now. So even if i buy motor and controller that are capable of more power, they will be limited by the battery and bms?SlowCo said:Yes the whole system needs to be compatible with each other. Basically the battery and its BMS determine how much power you can extract continuously and for a short peak. The 1800W continuous that the battery you linked to can provide should be enough to reach and maintain moped speeds of max. 50km/h. As Greece is part of the EU it probably will be mandatory to have the conversion to EV examined and approved to fall in the L1e class (mopeds with maximum cont. power of 4kW and max. speed of 50km/h). If you don't do that be aware you'll be riding an illegal motorized and thus uninsured vehicle. https://en.wikipedia.org/wiki/Vehicle_category
That is the most helpfull answer i've read! Thank you.Dui said:Sorry to say it, but that's not really the nost appropriate frame to do an electric conversion, it will make things more complicated than you original plan to use a scooter.
First reason being that it will not be very easy to fit batteries in there.
Second reason being that I'm not sure the rear swingarm will be wide enough to fit a hub motor.
Third reason is that the brake system is terrible and you'll have a very hard time to upgrade it
Not saying that it is not doable, but it will not be easy.
So, first thing, check how wide the swingarm is and check if you can fit a QS hub motor in there. Inboard motors are much more complicated to install and I wouldn't recommend it for a first build, you need to keep things as simple as possible if you want to make it work, otherwise you'll hit major difficulties and will be discouraged.
Regarding the batteries, I think the only choice here will be to make some saddles and put the batteries there.
On first page, you mentionned reaching 60mph, and 50mils of autonomy.
I think you can easily achieve this with a 2-3000W hub motor, a 100-150A controller and a 72V, 30-50Ah battery.
3000Watts motor over 2000W motor if you want reliability
150A over 100A controller if you want acceleration (150A will be very powerfull, I'd say at least twice the power of the original gas engine)
50Ah over 30Ah battery if you want range. You should select your battery depending on what will be your final power, for instance, you can't go for a 30Ah battery if you're using a crazy powerful controller. But we'll help you on that later, don't worry.
As for speed, it usually depends on battery voltage (but also wheel size). I'd say 72V should be able to reach 60mph with that wheel size, but if you want to be absolutely sure, then buy a controller capable of flux weakening, this way you'll be able to get a nice speed bonus and you'll have the possibility to set whatever top speed you want (within reason, of course).
vagosofron said:A hub motor is my preference, but a middrive is cheaper.
Unfortunately i can't find a hub motor in EU that can beat the price of a middrive kit i found that includes a 50a controller.Dui said:vagosofron said:A hub motor is my preference, but a middrive is cheaper.
I'm a bit surprized by this, are you sure?
What motors did you compare?
If you have all the necessary tools and know how to use them then it's a very good start.
Next important point would be for you to figure out a ballpark figure of the budget you're planning to allocate on this, because many things will depend on it and it will help you to decide where you should make compromizes.
vagosofron said:Unfortunately i can't find a hub motor in EU that can beat the price of a middrive kit i found that includes a 50a controller.
Dui said:vagosofron said:Unfortunately i can't find a hub motor in EU that can beat the price of a middrive kit i found that includes a 50a controller.
50A is quite weak.
It won't be thrilling performance :wink:
What's your budget for this build?
