Ratking said:
Bazaki said:
Very nice video ! I hope you will continue this project. Does anyone know the rpm of a jet prop of a jetski ? A boat prop is about 2500 rpm I thought
I know that most of the stand up jet skis using 701-750 ccm motors have rpm limit around 7500 rpm.
Thats why someone have to link a few of the 80-100 180kv motors togheter and try combined with hv160. That gives 8500 unloaded. That's perfect for a ice replacement.
What would be the best motor? Is it any calculation? math or physics formulas for jet motor and pump?
Turnigy 80-100 ~$100
Turnigy CA120-70 Brushless Outrunner (100cc eq) ~$450
Turnigy RotoMax 150cc ~$420
PERM PMG-132 24-72V 19.1Hp 7.2kW ~$1000 25mph Sparky: https://www.youtube.com/watch?v=QYKE5hQnXbM
Maybe those??
New Guanlian 48v 1000w brushless dc motor ~$??? (will update)
80WD-M02430 ~$130 in China + shipping $130 to USA ??
110WD-M04020 ~$160 in China
Model: 120-70-15
Resistance: 0.004ohm
ESC Required: 250A
Input Voltage : 30~70V
Kv : 150 rpm/V
Weight: 2730g
Shaft: 10mm
20v Non Load Current: 13A @ 20v
Dimensions: 150x120x118mm (Including Mount)
Equivalent: 110cc Twin Gas Engine (20hp+)
Battery: 14 Cell / 51.8V
RPM: 150kv
Max current: 190A
Watts: 9800w
No load current: 51.8V/5.2A
Internal resistance: 0.011 ohm
Weight: 2530g
Diameter of shaft: 10mm
Winding: 8T
Stator Pole: 24
Motor Pole: 20
Stator Diameter: 101
Lamination Tickness: 0.2mm
Suggested ESC: 250A 14S Compatible
Perm PMG-132 19.1HP ~$1000
Voltage: 24-72V
Weight: 24.8 lb
Angular-velocity constant: 50.2 rpm/V
Torque constant: 27 ozf·in/A
Terminal resistance: 0.025 Ohm
No-load current: 6A
Rotor Inertia: 1370 oz·in_
Inductance: 19 µH
Continuous current: 110A
10 minute current: 200A
Terminals: 8mm
48V Performance Peak efficiency: 86%
Peak power: 19.1 hp
No-load angular velocity: 2380 r/min
Stall current: 960 A
Stall torque: 25600 ozf·in
72 V Performance Peak efficiency: 88.6% *
Peak power: 34.3 hp
No-load angular velocity: 3590 r/min
Stall current: 1440 A
Stall torque: 38500 ozf·I
Voltage 24 36 48 60 72
Current 110 A 110 A 110 A 110 A 110 A
Power 2.2KW 3.5KW 4.7KW 5.97KW 7.22KW
Speed 1080 1700 2300 2870 3480
Torque 20.5Nm 20.5Nm 20.5Nm 20.5Nm 20.5Nm
