Samd said:Conrad can you drop me a line? I can't seem to pm you. Still want to swap that motor core over.
WESTART00 said:It's 72Ah capacity? weight 1.8kg? peak 8C discharge rate at 584 Amps?kiwiev said:Here are some CAM 72 CALB cells compared to my old 160Ah prismatic cells these cells can give 584 Amps for 10 seconds and weight 1.8Kg
Cheers Kiwi
That is the best option yet in my opinion. Then you could just easily add capacity to the cells you move over to the ute to give it extra range.kiwiev said:So another option is take the motor, controllers and batteries out of the sonic and use in the ute and then give the Sonic 7 the treatment
A wee video of Sonic 7
Hillhater said:"testing at 75%" ..? ...
75% of what ?... battery charge, current limit, ? ?
:lol: :lol: that brought back memories of doing similar "testing" many years back ( a teenage hoon ) on a friends property with a bush basher we had just put a low diff in. ended up taking out his mums flower beds, a fence, and the Vicars car that was parked on the road !! :lol:
.....we had forgotten to connect up the brake lines again !!
boy, if i had acreage now i would certainly build a "test track" !
Congrats mate Lee says Hi too boy or a girl?Cowardlyduck said:Looks amazing mate. I wonder if it will improve (or not) your efficiency at higher speeds?
I would say you should have popped by while you were up, but I got a 2 day old newborn now so things are pretty hectic. :lol:
For the front wheel lifting shot, try mounting the gopro underneath the rear of the car facing the front. It will clearly show any lift that way and look impressive also.
Cheers
kiwiev said:When to Canberra yesterday and my 6mm Polycarbonate tinted had turned up.
Cut a oversized wind screen out and fitted to the Sonic WOW
oatnet said:kiwiev said:When to Canberra yesterday and my 6mm Polycarbonate tinted had turned up.
That looks great!
Yep me. Hmm new news on the bike front very soon.kiwiev said:That you Tony?
Thanks mate, yeah I agree about the Winstons but they are still good bang for buck.
Cheers Kiwi
Ps hows the bike going?
kiwiev said:Thanks JD
Looks like I maybe able to get some A123 modules check your spot weld thread but I will have break each module in half to get 46 volt blocks any thoughts on this is it easy :x
Cheers Kiwi
oatnet said:kiwiev said:Thanks JD
Cheers Kiwi
Hi Conrad!
As excited as I would be for you to try a123, sadly, cutting them in half is a challenge. Cutting the metal joiners between the cells is simple. The pack is held in tension with a stainless steel band, you'd need to cut it, fabricate new end caps to keep even pressure on the cells, and retension them with new bands. The more difficult part for me would be fabricating new power take offs connected to the metal joiners on the power tabs. I've long thought about how to build a power path to bypass a bad cell, and can't figure it out. I was unable to solder to the cell joiner (it is too large a hunk of metal to get hot enough), it is too thin/soft to drill and tap, and I don't think spot-welded tabs to the rough surface would carry the amp loads I was looking for. These cell joiners are laser-welded at the factory.
Wb9k works for a123, and did do some sort of surgery on a module for his "miles" build, he might be able to tell you more if you ask him in a PM:
https://endless-sphere.com/forums/viewtopic.php?f=34&t=67989&start=50
-JD
