dumbass
Midnightrider, Glad you like your purchase but I'm a little confused on your chose of charger. I can understand you wanted a 36v throttle to use the voltage lights ( but that's the only reason you needed it). I'm assuming you are still using the original 2 24v packs as 24v and connecting each of them to a 3rd 12v battery to make 2 10ah 36v packs. Correct? There's no reason that you had to have a 36v charger because in a sence you still have 3 24v packs. Of course your breaking one in half to add it to your others to accomidate the 36v. I assume you needed to charge faster anyway which would have required another charger. If you haven't already done it I would recommend that you put a jumper between the 2 26v packs. This will reduce the wear on them and give you less voltage sag while riding.
BTW, how long have you been running on the 36v? And how much are you actually using the full throttle while riding?
Bob
Bob
