voicecoils
Hi all,
I spent a bit of time playing with my Cycle Analyst (direct plug in model) with my Bafang hubmotor. Since the geared hubmotors have a motor speed higher then the wheel speed, and the Cycle Analyst (CA) determines speed from the hall sensors, extra setup steps are needed to get wheel speed and distance to display correctly.
My motivation for trying to correct this was twofold:
* Firstly speed was being displayed incorrectly (much too high)
* Secondly, the max speed limit I can set is 99kph but the corresponding motor speed was much higher, so the controller was cutting power to the motor above this.
For the Bafang motor, here were the peices of info I needed:
* Gear reduction: 4.3:1 (so if the motor spins 43 full revolutions, the wheel turns 10 times)
* Motor poles: 10 pole pairs (this is set in the CA advanced menu)
I altered wheel size field by dividing my actual wheel circumference by 4.3. My 26" wheel with large tires comes in at 2100mm, so I programed wheel diameter to be 488mm. Now I am getting a noload speed reading of ~62kph at 79-80v. I'll do some riding tomorrow with my GPS and compare speed accuracy.
Another thing to note is that some geared hubmotors have a freewheel (including the Bafang). This means the plug in CA cannot correctly measure distance as distance traveled while the motor freewheels will not be counted. If you use a small bike computer that measures speed and distance, you can use the distance info along with the watt-hours (Wh) consumed on the CA to determine the all important Wh/km or Wh/mi figure.
Anyone have any other CA and geared hubmotor tips?
