So yesterday I was going to do a long ride to measure full discharge of my batts and other stats. Everything was working great for the first 15 miles until I got a flat, on front wheel with the motor. Considering what a PITA it is to fix it, I didn't even cary spare tube/repair tools.
So there I was, 10 miles away from home. The usual bailout option of taking subway home also didn't look appealing with 100lbs bike (for that particular situation I had 6 flights of stairs to carry it through). So i tried riding it home flat, slowly... I now realise how stupid that idea was. I've learned the hard way that flat tire has no sideways traction. I've wiped out when turning at something like 5mph.
So now, the reason why this is in Technical section. Considering that flat tire is pretty much the worst thing that can happen to an e-bike short of bent dropouts, what tires/tubes/rim tape do you go guys use? How many miles between flats for you on average? What is your tire rated PSI and what do you inflate to?
My Stats:
e-bike: smooth 26"x1.9", 65 psi, inflate to 65 psi, slime tubes, 50 miles before flat
Commuting bike: 700Cx35mm, 90psi, Kenda, no flats in 500+ miles
road bike: 700Cx23, 120psi, flats on average every 300 miles in 3000 miles total, no flats after switch to michelin kevlar tires.
Also peculiar is my most frequent flat type: ripped out valve stem. Do you ever get it? What causes this? How can I avoid it? I've tried different tubes, using locking nut on the valve stem, not using it, same results. I've even got this failure on bikes i'm not riding, just keeping inflated!
My Stats:
