Hi all
I thought I would give you an update with some performance figures after a few weeks of commuting.
I'm only riding to work two or three days a week, but that's way better than none.
I am finding that I use less Ah than my predictions from swbluto's simulator, and I think the main reason for this is that I'm probably pedalling a bit more than estimated, and the bike seems to be a little quicker going uphill than I expected, which keeps the motor efficiency higher.
For the journey to work, I use a little over 2 Ah, and about 3.5 Ah for the return journey (5 Ah capacity, recharge at work).
I spend most of my time between 30 and 40 km/h (19 to 25 mph) mostly using light pedal assist, heavier assist uphill to keep speed up.
Some sample power figures from the Cycle Analyst:
Flat ground, pedalling, 40 km/h (25 mph) - 360W ...uses 9 Wh/km (14.5 Wh/mi)
Flat ground, no pedalling, 40 km/h (25 mph) - 550W ...uses 13.8 Wh/km (22.1 Wh/mi)
5% grade, pedalling, 35 km/h (22 mph) - 900W ...uses 26 Wh/km (41 Wh/mi)
11% grade, pedalling, 30 km/h (19 mph) - 1100W ...uses 37 Wh/km (59 Wh/mi)
