heynow9991
- Joined
- Feb 1, 2016
- Messages
- 40
I have an old ebike I am trying to fix. It has this Crystalyte hub motor on it. I cant get it to work so I took it apart and it looks like the wires going into the hub are damaged. I also measured the voltage to the hall sensors with the controller powered up, and I would get 5 volts continuously when I moved the wheel. I assume that the hall sensors are blown?
So I would like to know what motor this is, and is it worth fixing? I have never done hall sensors but I think I would be able to do it.
The hub motor is at least 5 years old. It looks like it says QM1012R10120 on the cover
Thanks
Thanks
