Those are serious motors. I would love to try those.
I would not go with a cheap controller. I believe the top motor id brush. Not sure about the lower but if only two motor wires and no sensor wires it is most likely a brush.
If it were me I would go with a Kelly controller.
To see connectors' detailed dimensions,click here .
kellycontroller.com
They are fully programmable so can get a smooth safer start and operation. You have some really scary motors there so a Kelly controller can do a better job to tame the beast. I think that would be much safer then some of the controllers listed above.
Please do not take my word for it though as I am not allowed to give advice here. ust ask the other members what they think about Kelly controllers. I would order one but that is me. They are not really that expensive either for a quality name brand controller and the company has been around a very long time.
As far as the battery I use LIFEPO4 packs made from A123 cells. If you have a friend or are handy with a spot welder a 13S - 8P 43V pack is doable with an 80 or 100 amp Bluetooth BMS. I run 13S LIFEPO4 which is 43 working volts for 36V motors and 16 or 17S for 48V controllers.. I am developing a non weld or solder less kit where only the power wires need solder. All series connections will be solder less.
However until I get a 3D painter my idea is just an idea in the engineering stage so you are better off ordering a factory built LIFEPO4 pack or finding someone or learning how to spot weld a pack yourself.
Make sure you put fuses in. You can never be too carful. You can actually use two fuses. One for hot and a second for ground. Just be very carful if assembling a pack yourself. I am not advising you to do ANYTHING. , However if you do look at you tube videos showing how it is done from start to finish and don't hurt to watch it over several times.
The last thing you want is a cheap no name brand 18650 Lion pack. They can catch on fire. At least a name brand like Samsung (if genuine ) will have some cell protection circuit built in the top of the cells. FAKE Chinese cells do not so BEWARE.
I myself like Bluetooth and want to monitor cell voltage all the time. , during the charging and discharge cycle. I never leave the job to be done with a BMS active balancer NON Bluetooth. I do not trust it. If the BMS is not Bluetooth a separate balance plug and an external balancer can work to make dam sure the BMS is doing its job.
Good luck.
Skyler out.
Thanks.
Skyler.
