betarambo
It is a long story that has lead me to asking for your help so I will try to keep to just the details you need in order to solve my problem.
I bought the controller and ran it for a while with no problems except that my motor had problems. Along the way I programmed the controller while experimenting with different combinations. The last time I tried programming it, it never took the new settings. I got to looking at the programming cable and found some suspect looking wires where maybe they got bent too far and broke.
I ordered another cable from Lyen but it sat for a few weeks while I worked on other parts of the project.
Today I find that I cannot program the controller and the controller will not spin the motor. When I run the software with the cable connected and start the transfer, pressing the button does not lead to the transfer happening. I do see that messing with the button can change the blink rate of the text on the software, but the progress bar never starts.
I have tried three different USB ports just to be sure. I verify that I am using the right com port by checking in device manager. I am using the same laptop and software install that worked before. I tried creating a new ASV file from scratch as well as the one Lyen sent me, I disconnected all other wires from the controller. I have emailed Lyen and I am waiting for a response, but the guy doesn't charge enough for me to expect him to drop everything and help me every time I ask (even though he was awesome last time I had issues). I have done a lot of reading on this forum and tried a lot of things based on that, but I am still stuck.
Any ideas?
Any ideas?
