MD.
1 W
Hi,
I purchased the CON62 controller from greenbikekit.com to use with a Bafang SWXB. I also purchased a couple throttles, the LED meter, and a PAS. The controller arrived with the LED meter connected and the PAS wired as well. The PAS was wired a little strange as the middle pin green was wired to the 4th wire of the LED meter connector. The 4th wire of the LED meter was not plugged into the connector. When I purchased I hadn't planned on running the PAS with this setup. I just threw it in since it was only a couple bucks and I was shipping from China.
Anyway, I disconnected the PAS from that 4th pin, put the LED pin back into the connector, and wired every thing up. I also connected the Orange wire to the Red power wire. A diagram of the KU63 showed that this is for an On/Off switch. I just need it in the On position until I actually put a switch in.
Upon testing I didn't get any sound or motion from the motor. I began researching and learned that there are two versions of the KU63 from bmsbattery.com. One version requires the PAS and one doesn't. I've also read that the one that does require PAS, has a jumper I could cut to enable it to work without the PAS. I looked for this jumper on my CON62 but I don't see it.
Thinking the problem was just the PAS I connected it back up the way it was. I then put the magnet ring on a drill and ran it over the sensor to simulate crank installation. Unfortunately nothing happens. The hub motor acts like noting is being sent to it. Maybe I'm not simulating riding fast enough.
I've checked all connections and I know power is going somewhere as the LED meter lights up and I can select the three speeds. My RC watt meter reads around .1a of draw. I'm pretty handy with a volt meter, I just don't know voltages to check for or where. If anyone here could point me in the right direction, I would very much appreciate it. I'm also going to send an email to GBK to see if they have any ideas or suggestions.
One other bit of information I want to add is that I'm running it off a 16s Headway LiFePo4 battery. It's the only one I have right now and I've read that it should probably work. I plan to use a 36V LiFePo4 when it arrives. I've read that the CON62 should be fine for testing at 48v. Before wiring it up I checked the Capacitors and they're 63v.
I can't really find any wiring information. Attached are pictures of everything. If you're willing to help, let me know if I can provide any other images to assist.
Thanks in advance everyone!!
