rogerc said:
I am getting a complet kit ... from Celllman at EM3 and getting it all plug and play.
Have ordered the Cycle Analyst 3.0 as part of the kit.
I was reading on different sites about how to use the CA 3.0 and was over whelmed by a lot of it.
Stunts, lots of menus, electrical lingo etc.
In reality how hard is this to set up with the whole kit for someone on their first build?
The short form:
I would say that because you bought it from EM3EV, this should be simple to get working in basic form, but will require some added effort to exploit more advanced features.
The long form:
As you point out, the kits from EM3EV are plug and play. This should address the hardware installation aspects of the V3 installation including modification of the CA for the LM35 temp sensor if you are buying a MAC (not sure about temp sensors on the DD motor).
I have not ordered a V3 from Paul, but from discussions with him a month or so ago, he indicated that his V3s were being shipped to customers with basic V3 Setup configuration already in place. I believe this will take care of shunt, throttle, and other basic configuration tasks so that your V3 will be operational out-of-box in a basic V3 'normal' operating mode.
The V3 has many features, some of which interact in non-obvious ways. Although it is easy to use once set up, the setup procedure itself can take some patience.
- I recommend that before you make any changes to your V3, that you:
- Download the most recent Setup Parameters Document from this page and print it.
- Download the Unofficial Guide
- Read sections 1 and 2 of the Guide (through page 9) to familiarize yourself with the unit, screens, and basic console button operation
- Enter Setup and traverse each section, recording the settings that Paul provided on the printed forms. This will allow you to restore the unit to 'out-of-box' condition if you make configuration changes with undesirable effects.
- Save this completed Setup Parameter form for future use. Certain settings from the Calibration section were done at the factory or by EM3EV and are specific to your unit. Recording these settings ensures that you unit can be restored to operational condition without difficulty.
To be truthful, even for basic operation the v3 requires more effort to configure than the older V2 model described by
pdf in a post above. However, EM3EV will have done this for you, and the Guide details the steps in any case.
Your post seems to indicate that electrical/technical stuff is not a strength - this should not pose a large problem should you wish to modify the basic configuration or enable some of the V3 advanced options. The
Guide may prove helpful, but if it does not, a post to the
CA V3 Beta thread or a new thread with your questions will get some assist.
- In any case, there are no settings that you can make to the V3 that can damage your bike or the unit itself, so a little fiddling to tune things up is always 'safe' - don't be afraid to have at it. And of course, with your recorded Parameter Setup form, you can always restore things if configuration experiments get you to a Bad Place.
So - this is not as easy as plugging in a toaster, or even as configuring a V2, but with a little attention to detail, it should be quite manageable with or without added forum assistance.
Other Stuff for the first time builder:
- Here is a handy little guide from ebikes.ca for the newbie builder that may help you with some basics and terminology.
- If you did not order one, you will need a USB programming cable for the V3 - you can get this from EM3EV, ebikes.ca, or direct from other sources as described in the Guide. The present software is Beta and the cable will allow you to upgrade to newer software and functionality as it becomes available. When doing an upgrade, you should once again record your Setup Parameters on a fresh set of forms to preserve not only the most contemporary configuration but also historical information such as total mileage. You can then restore this information after the new firmware is installed.
- At some point, something will stop working. Getting an ebike tester will help you figure out what's up. These are best ordered with your kit from EM3EV to save postage, but can be had on eBay or from Lyen. I't best to get this advance and outfit it with extended leads and connectors to match your build. Plugging it in while your bike is healthy to see how things should look is Good. This thing may not make a lot of sense to you at first, but it will be helpful to diagnose problems if you write in to the forum. Here's a link to a little manual for the unit - EM3EV now provides one as well.
- And of course, pick up a digital multimeter - even a cheapie one will do.
