I'm not saying you are on the wrong track here though. I built a bike specifically designed to climb the rocky mountains on 1200w of max power measured going into the controller. 22 amps controller, 14s battery, or commonly called 52v. My goal was to reach a max speed of no more than 20 mph, and be able to tow a trailer up the rocky mountains without overheating the motor. 400 pounds max load, bike, a crapton of batteries, trailer, and my fat ass. 20 inch rear wheel, 10t wind, dd, 500w rated motor. "9 continent type".
Its still the best bike I ever built, although the damn things battery did burn my garage to the ground. The slow motor limited my speed, increasing efficiency simply by making throttle creep faster impossible. 18 mph for the bulk of the ride on flat ground, and pulling an actual 800w, it would climb an 8% grade at about 10 mph, yet the slow wind kept it from overheating as a 7t motor would tend to if the climb was long enough, and the load was 400 pounds. In 7 t, youd need to keep it turning more like 14 mph, which would require more like 1500w, using a 40 amps controller.
