...or current.John in CR said:All of the windings climb the same, have the same torque, same efficiency, and can run in the same size wheel. It only takes a different combination of voltage and current for the same power input to get the same torque, speed, and power out at the same efficiency. The only time a different winding needs to come into play is if you're already locked into a specific voltage...
ebike4healthandfitness said:John in CR said:Ianhill said:MadRhino said:The difference need to be expressed as a percentage. If a slow winding does 30 mph at 72v it will have the same % speed drop at lvc as a fast winding doing the same top speed at 48v, simply because the fast winding will drop more rpm per volt, proportionally.
Learn something everyday never thought of that.
So to lose less rpm as possible use low volts and high turn counts
Down side little current handling and the speed is gonna be crawling so efficiency will suffer.
Think between you all its answered here
That's not at all what MadRhino is saying. He's saying it doesn't make any difference, because the % change in voltage is the same. Just give up trying to invent a condition where it's better to use a slow wind motor, because there isn't one unless you want to go really slow and you're sure you'll never want better performance.
To me it's pitiful that anyone needs to suffer with a slower bike at the end of a ride than the beginning, and that's especially true for those who want to stick to some arbitrary letter of the law written by people who are extremely prejudiced against ebikes. The way around the problem is to build the bike with excess capability and limit the top speed via the controller. Then you can ride the speed you want at all points in the discharge cycle as well as on uphill grades and into headwinds.
One thing I have noticed when comparing Clyte H3548 and Clyte H3525 at higher power levels in the motor simulator is that the slower wind Clyte H3525 at high voltage will do better than the faster wind Clyte H3548 at low voltage.....in climbing and top speed.
H2525 @ 72v with 20" wheel:
32.5 kph climbing 14% grade with 61.1 watt-hours per km power consumption
43.3 kph top speed on flat ground
H3548 @ 36v with 20" wheel:
22.6 kph climbing 14% grade with 62.9 watt-hours per km power consumption
40.6 kph top speed on flat ground
https://ebikes.ca/tools/simulator.html?motor=M3525&cont=PR&batt=B7210_DT&wheel=20i&grade=14&hp=0
https://ebikes.ca/tools/simulator.html?motor=M3548&cont=PR&batt=B3626_GA&wheel=20i&grade=14&hp=0
https://ebikes.ca/tools/simulator.html?motor=M3525&cont=PR&batt=B7210_DT&wheel=20i&grade=0&hp=0
https://ebikes.ca/tools/simulator.html?motor=M3548&cont=PR&batt=B3626_GA&wheel=20i&grade=0&hp=0
With the H3548 being almost twice the wind as the H3525 the results should be a lot closer. The only thing I can think of is that the phase wires are too thin to optimally handle the higher current needs of the 36v and this is why the slower wind H3525 is so much better at climbing.
markz said:A) I would much rather have larger diameter winding wire that is shorter which means less resistance but it can take more power which means low turn count motors (3T, 4T etc)
B) then a motor with thinner diameter winding wire that is longer which means more resistance can cant take as much power which means high turn count motors (8T etc)
ebike4healthandfitness said:markz said:A) I would much rather have larger diameter winding wire that is shorter which means less resistance but it can take more power which means low turn count motors (3T, 4T etc)
Been running some simulations in the motor simulator keeping battery pack and controller constant. The only variables I am changing is wheel diameter and motor winding (Clyte H3525, H3540 and H3548).
All wheel diameter and motor winding combinations I matched up to produce the same top speed on flat ground, but the smallest diameter wheel with the fastest winding (i.e. lower turn count) climbs fastest while at the same time running coolest and using the least amount of power of km. This tested on various grades.
P.S. One thing to keep in mind is that as tire diameter decreases a person who wants to pedal along with the motor will need a larger chainring and/or smaller cogs in order to keep up.
ebike4healthandfitness said:All wheel diameter and motor winding combinations I matched up to produce the same top speed on flat ground,
John in CR said:To me it's pitiful that anyone needs to suffer with a slower bike at the end of a ride than the beginning,
For a hub motor, smaller wheel will always produce better efficiency for a given speed and load, because it doesn't need to produce as much torque for that given load (smaller wheel= more leverage). Since heat is proportional to torque squared, reducing the torque requirements significantly reduces heat produced, and therefore increases efficiency.ebike4healthandfitness said:but the smallest diameter wheel with the fastest winding (i.e. lower turn count) climbs fastest while at the same time running coolest and using the least amount of power of km. This tested on various grades.
john61ct said:Very high weight loaded tandem / cargo rig, long steep mountain climbs, none of those fixed values, #1 goal is just to maximise them.
Need maximum torque at low speeds,
Any system voltage between 24V and 72V is OK, whatever works out best, never mind cost issues due to higher voltage,
Balmorhea said:ebike4healthandfitness said:All wheel diameter and motor winding combinations I matched up to produce the same top speed on flat ground,
That's a sign that the speed is power limited and not motor RPM limited. It's likely that every one of those windings is faster than optimal for the voltage and current you specified.
@John in CR do you agree?Balmorhea said:Any winding can put out the same maximum torque, as long as there's the same amount of copper. A winding that's three times as fast can take three times as much current (the winding, not the plugs and phase wires)...It doesn't matter.
ebike4healthandfitness said:ebike4healthandfitness said:John in CR said:Ianhill said:Learn something everyday never thought of that.
Regarding the comparison above.....
......Phaserunner is not able to supply enough amps to the fast wind motor (Clyte H3548) during the climb.
Ianhill said:ebike4healthandfitness said:markz said:A) I would much rather have larger diameter winding wire that is shorter which means less resistance but it can take more power which means low turn count motors (3T, 4T etc)
Mxus 4t on 10s 10wh per mile is not to bad, I had a 16tooth rear single and 52t front 20 inch rim peddle at 16 mph to peddle at 28mph on a 20 will be spinning legs like no tomorrow.
That's about the limits of what I got to help sorry fella I'm sure you will pick wise though.
john61ct said:"Taking" lots more current, does that translate to running cooler at that low speed power (torque) level?
How practical is 72v (or 60v) for a street legal direct drive set-up meant for climbing and sub 28 mph speed?
ZeroEm said:It only takes 48V 25A controller in a 26" wheel for <=28mph
ebike4healthandfitness said:ZeroEm said:It only takes 48V 25A controller in a 26" wheel for <=28mph
Yes, 28 mph with a 26" wheel, 48v battery and 25 amp controller is possible with a Clyte H3548:
https://ebikes.ca/tools/simulator.html?cont=C25&motor=M3548&mass=170&batt=B4816_GA&hp=0
.....but that same 25 amp controller limits the climbing speed and climbing efficiency of the fast H3548 wind compared to the slower H3540 and H3525 winds:
https://ebikes.ca/tools/simulator.html?cont=C25&motor=M3548&mass=170&batt=B4816_GA&grade=7.5&hp=0
H3548 up 7.5% grade yields a speed of 10.9 kph at a power consumption of 96.6 wh per km
https://ebikes.ca/tools/simulator.html?cont=C25&motor=M3540&mass=170&batt=B4816_GA&grade=7.5&hp=0
H3540 up 7.5% grade yields a speed of 15.3 kph at a power consumption of 75.8 wh per km
https://ebikes.ca/tools/simulator.html?cont=C25&motor=M3525&mass=170&batt=B4816_GA&grade=7.5&hp=0
H3525 up 7.5% grade yields a speed of 17.6 kph at a power consumption of 66 wh per km.
