Braddudya
- Joined
- Jan 30, 2022
- Messages
- 140
Been reading all that I can here. I want to build a 52V battery for BBSHD emtb conversion. I have assembled packs before using 60 LG cells for a mobile power station. This was before I could find affordable spot welding equipment so it was the "work as fast as possible with a very hot soldering iron" technique. This time I want to do it right and make it as safe as possible. I live in Reno and my biggest concern is an accident while out on a trail. We have some significant fire risk around here.
What I have decided so far:
1. 18650 lithium ion cells
2. Will carry a fire extinguisher on bike (not so much for putting out the battery, but more for putting out anything around the bike in case of thermal runaway)
3. Will charge outside or at my warehouse.
What I am considering:
1. Single rows of cells in a triangular shape within my frame
A. This should help reduce a chain reaction or at the very least slow it down by reducing density without sacrificing space efficiency.
2. 3D printed custom battery case. (I have 6 printers which I run daily)
A. Allows for a perfect fit within my frame and allows for the minimal density design.
3. Salvaged lightly used name brand cells
A. Looking at options from Jag37 and batteryhookup
B. I will do whatever is needed to test for good condition cells.
What I need is advice on:
1. How is my plan so far?
2. What are the best ways to up the safety factor of such a battery?
3. Are there any must watch or must read resources I should be focusing on?
Once I get the safety features planned out I will be looking into the optimum BMS so any advice there would be hugely appreciated as well.
