tmho
I have a 48V 500W rear hub motor. I have not yet installed it to a bike. I have tested it. The no load maximum speed is just around 30km/hr. I wanted to increase the maximum speed to about 40km/hr under load. My weight is just about 140lbs. Can I do that just by replacing the controller with a 800W or 1000W controller?
In such a way, I think the current will be increased. But when I check the cable coming out from the hub motor (as attached), the wires seems quite thin. Will the wires be able to handle the increased current?
In case the wires are too thin, I want to replace the cable with thicker wire. I have searched ebay using "hub motor cable", but I could not find any similar cable (with 5 thinner wires and 3 thicker wires). What is the correct name for that cable?
