DAND214
You will be able to run 48v with that setup, but not 24v as the controller will hit LVC and not run. the throttle will funtion but your battery level guage will not be any way near correct. As most aren't anyway.
You should like the 128 hub and speed of 20mph on 36v without a problem.
Are you going to mount the battery in the front with the hub motor? It will be way too hard to control with all the weight that far forward and so high. put it in the frame or on the rear, if at all possible.
dan
dan
