MarkJohnston
- Joined
- Mar 25, 2021
- Messages
- 620
Hello,
I've been recently having a lot of INTERMITTENT issues with my bike. It all started with my controller when I shorted it. Now the hall sensor only works INTERMITTENTLY. When the hall sensor is plugged in I will get voltage/wattage drops. Suddenly the bike will jerk (best way I can describe it, like regen but I don't have that). unplugging hall sensor seems to work but now I have noticed new issues.
I noticed my batteries are discharging UNEVENLY. I have two hooked up in parallel. They only discharge UNEVENLY INTERMITTENTLY. They only do it sometimes. I smelled burning coming from inside the battery CASE. I opened it to find the Fuse plastic on the DISCHARGE side completely melted, and the plastic housing BURNT. However the FUSE still works. Oddly enough it seems. I still replaced the fuse and tried the battery again and it discharged EVENLY this time. Knock on wood that fixed it. The issues is I have two other batteries of the SAME MAKE AND MODEL, and they also do the same thing. Sometimes they DON't discharge, also sometimes they don't CHARGE EITHER, or don't reach nearly full charge and cut off early...
What's going on here ebike wizards? I have some ideas but I first want to hear what you guys have to say just so there is not bias because of what I think is the problem.
UPDATE:
Ok so I've read all the answers so far. Here is maybe why I am experiencing the issues.
1) The controller was shorted out and is affecting wattage and output. It could be causing SURGES in the electrical system causing the LEDs to be damaged (hooked up straight to battery no fuse). REad above about how the controller works better without the hall sensor. Sometimes it still cuts out there(interference from a radar tower maybe? It always cut out in the same spot on my commute or maybe it's just a sharp turn that throws off the sensors.)
2) the batteries are getting old and the BMS is old or damaged. IT's not giving the right commands to the battery. I did short out the battery a couple times I think.
3) A lot of the wires in the Parralel wiring harness that I made have lots of broken strands under the electrical tape. There is mechanical stress on the wires they are constantly being bumped and pushed on. This is where they are soldered to the connector. The solder has come loose many times so I Carry multiple harnesses.
4) I use cheap chinese chargers that I got for $10 YEARS ago. I've done hundreds of charges on them. Maybe using those chargers over time has ruined the batteries? I wonder. I just didn't know how expensive ebikes could be. I just wanted one. I didn't think long term.
UPDATE:
