hagerty1
- Joined
- Nov 4, 2014
- Messages
- 35
I am doing a trike project. Battery pack 14s x 14p /Motor 1000w/Infinion 12fet controller all will be mounted in the back. Pack and controller will be in a sealed waterproof aluminum diamond plate case used as a heat sink for controller/converter. I need to run control wiring forward. My question is can I use a common ground wire for all controller functions ? Throttle/3SP/E-brake lever/cruise/reverse ? I want to just run a single ground wire to front of trike and use it as common. I am planning to use 20 Ga. wire for all control functions as these are all low current functions.
All phase/hall and main 49V power will stay rear.
I will also be running 2 16 Ga. leads forward Pos/Neg from a 48V-12V converter for running GPS/Lights/Stereo/Horn
The converter will run off the pack. I know this is a stupid question......can that converted 12V Neg. be used for controller function ground ?
I am using a combo full twist throttle/3SP/Cruise on right and a combo high/low light/momentary push button reverse.
I am trying to run as few wires forward as possible as they will need to be around 7 feet long routed through the frame. Can I consolidate/centralize any of the other leads? 5V Pos?
I will have a small junction box on the front of the trike so I don't have to remove all the plug ends from the various controls, I will slot one side to allow control wires with their standard plug ends to enter box with lid removed and be sealed when lid attached.
Thanks for any help
Jim
Thanks for any help
Jim
