eDahon
Ok so I went with the Kelly KBS24121L,50A,12-24V, Mini Brushless DC Controller. I have the equal zero design hall board and Turnigy SK3 6374 149kv
http://www.hobbyking.com/hobbyking/stor ... duct=18184
Lastly I am using 5s 5000mah lipo 20c
so I figured out the proper hall signal phase wire combo and the no load current is about 2.5 amps. It runs smoothly if I throttle up slowly but often cuts out at full throttle. I also can brake harshly if I throttle down too quickly. And when it is running near full throttle it hiccups violently and then will run smoothly and then hiccup again. I will then get a fault code on the Kelly controller. It is internal reset error
I was stuck on the fact that it was a problem with my timing or my sensor or board but I have now ruled that out. When I attached the motor to an amped bikes ebike controller with 36v lipo it ran extremely smooth no problems at all. I am now confident that it is a controller problem although I cant rule out the battery although it does seem unlikely particularly at the low current that the motor is pulling with no load and there is no noticeable voltage drop. It is at 19.2 volts
Do you think I have a faulty Kelly controller or is it a setting issue? Or is there any fundamental reason why this controller would not work?
Any help would be greatly appreciated!
Thanks!
Thanks!
