So, electric parts approached.
BMS for 24s. Interesting is that on the upper board (where is a second plug) we have not only 24 pin as last but also 25 and 26 number but without pins. So it is posible to using this BMS as 25 -26 cells bms also?
Driver is 12 fet 4130 as I remember correctly . And 100V capacitors.
Summary - it will be OK for this build.
Now I have other trouble.
I need to buy some cell logs or cell protect beepers. Was thinking about cellog8 but cant find on hobbyking.
They have same 6 cell versions but I dont now... Now thinking about something small but want to have possibility of manually correction of alarm voltage level (I have lifepo not lipo).
Well, yes I have a BMS and also cut off protecion in driver but.... Read some post then bms could be fail...
Oh yes question. (one more).
I have Turnigy acucell-8. So want this cell-protecion beper with the same kind of plug. But dont know the name of this connection (something like jstx or something). Sorry, up to now I was using to balancing my lion battery, computer pins and rs232 port plug
. But now, I thing its a time for something with most mainstream - typical setup.
Regards, Mike.
