Dunlop said:
PLEASE DON'T TAKE ME WRONG.... I APPRECIATE ANY AND ALL HELP HERE
I think you're doing very well putting up with everything.
I feel like it is more the other way around - THANK YOU ALL FOR YOUR HELP/INPUT!!!
I believe with no display present, your controller as set now (C3=8) will look to the last gear setting used and revert to that.
Or use the other gear settings on start up as set by parameter C3.
****From what i read today the jumper mode sets it at 2 or 3....*****
Previously I was looking ahead to the jumping of the display when discussing the "gear" position.
If I'm reading this correctly, with the setting you have now, your gear position when you shut down the system with the C3 parameter set to 8. Should be restored when you power back up.
See:
C3, page 23.
Is it? I.E. Set your gear to 3 on the LCD display. And when you reboot your system, does it automatically start in gear 3?
Or if you set parameter C3 to number 5, does the LCD gear start in 5 after rebooting system?
Looking to see if your display PAS communication is working...
Questions:
1. Does the jumper method utilize the PAS system for sure?
Everything communicates fine! C3 = 8 is my setting, and it always reboots where it was left it. I tried all other C3 settings (0-5) and it reboots just as it should (in the proper gear)... Everything working fine here!!
I did quite a lot of searching today, to see if the "Jumper Method" includes the usage of the PAS or just the throttle?? I can't find a darn thing that shows the motor running using the pedals, while being "Jumpered"..
So tonight I am down to just one question:
Can anyone confirm the PAS system works when the KT controller is jumper-ed to work (as described above), without a LCD hooked up??
Thank you,
Keith
