Allex
Which one are all excited about?
Allex said:Which one are all excited about?
Kodin said:The 35mm is the 1000W model, right? I am curious why the 1000W vs. The 1500W model...?
The 40mm model is the one I want to see on the sim. My reasoning is its the closest in spec to the similarly classed MXUS motor.
Yep. 28% wider stator on the MXUS.Samd said:Correct. 10mm more than leaf!
This is my first DD hub and at this power level it is not as exciting overall as the Mac. The Mac has a lot more off the line grunt but my seat of the pants tells me the leaf catches up once up to speed. For wheelies the Mac is hands down a lot more capable BUT with more power I think the leaf could be better as the power delivery seems smoother and more controllable.
__mike said:Temp sensor is plugged into the Hall plug with the white wire and reads either 0.5degrees or 240 depending if I select 10k or linear.
markz said:This is my first DD hub and at this power level it is not as exciting overall as the Mac. The Mac has a lot more off the line grunt but my seat of the pants tells me the leaf catches up once up to speed. For wheelies the Mac is hands down a lot more capable BUT with more power I think the leaf could be better as the power delivery seems smoother and more controllable.
Nice looking bike by the way. Well its good to know about your experiences with both motors. Why did you buy a 5T Leaf? Why not a 3T?
cwah said:You need to buy motor with bigger stator like the mxus 2 at 45mm to catch up with torque
HamsterPower said:__mike said:Temp sensor is plugged into the Hall plug with the white wire and reads either 0.5degrees or 240 depending if I select 10k or linear.
Is this why the Leaf temp sensor is also reportedly having issues with the Adaptto controllers?
spinningmagnets said:For commuters that are happy with 1200W (48V X 25A), the geared MAC is efficient and light. When you approach 2000W, there will occasionally be issues with the clutch and heat-shedding (as you have stated).
I think the extra weight of the Leafbike 1500W is unnecessary unless you are making the jump to 2600W (52V X 50A). If you raise the amps from its current setting, and add Ferro Fluid (FF), I think you will be much more pleased with the Leafbike motor. 2600W is a different league, but of course, the battery will lose some range compared to using the geared hub at 2000W.
You don't have to explain why you would want a full-suspension frame for the street, but if used for off-road, I highly recommend investigating mid drives.
markz said:So you already had a battery pack, and you based your motor wind on that. Is that right?
neptronix said:Try 4000 watts peak... that is when the Leaf will blow the MAC away at any wattage..
This motor does surprisingly well, heat wise, and power wise over 2000W.
