Samd said:. . . . that format is like the heineken of stators in china. . . .
I think he meant they're super common. Maybe like the Bud Light of America?Dauntless said:Samd said:. . . . that format is like the heineken of stators in china. . . .
Not sure I understand.This being the champagne of bottled stators? Or that they're often counterfeited?
No. Get a CA 3 with temp rollback and other goodies. A very different product than the 2.3 for an extra $30.MLC said:- CA 2.3 DP
Not a problem as long as long as the shifter and derailleur are the same brand. Der's aren't actually x-speed, the thing is how much they move laterally for a given length of cable pull. The shifter is what determines the amount of pull and thus needs to be matched to the cog spacing, meaning it needs to be a 7-speed shifter. DNP shares spacing specs with Shimano and SRAM so as long as shifter and der are both Shimano or both SRAM, you should be good.MLC said:Hi All,
- Plan for pedal drive: 2x7; 52+36 on crank - no front deraillure (move chain down by hand when I break down);11-32 DNP in back (not looking forward to lining this up with my 8 gear deraillure!)
That's a lot of battery. Better too much than not enough, of course, and if you want to pull a lot of amps on the weekends you'll need a lot of p's. But for reference, I used to do a 20-mile RT commute on a 12s 10 Ah pack and had no problem charging just once per day. You can make it even smaller if you charge on both ends.- Either 14S/7P GA's (Luna triangle) (but they don't seem to be available now?) or 14S/9P 30Q's (EM3ev triangle) (Just read the thread on the 30Q testing...great info!)
teklektik said:No. Get a CA 3 with temp rollback and other goodies. A very different product than the 2.3 for an extra $30.MLC said:- CA 2.3 DP
Get a temp sensor in the motor. Even if there are difficulties with the installed sensor (?), it's easy to change it compared to pulling new wiring to get a sensor wire installed.
Lyen = Infineon with a few mods (sometimes) and branding.MLC said:The thing I'm dreading now is going through the phase and hall wire combo's. I found the spread sheet to help with this but has there been any advancements in this area? Maybe all the Leaf 1500's/Lyen combo's hook up the same way(?). Any thread/pics/collaboration in this area?
A last note on the V3 - as an FYI - not a hard sell:MLC said:....You're probably right about the CA3 but alas I pulled the trigger on the CA2. My thinking is that I wouldn't use most of those pig tails so the CA2 would be neater and sufficient. I'll just be watching I/V/P for now and may want to log in future (which I believe the CA2 can do with some extra bits). I don't see myself pushing the temp like a lot of you guys do. Just a quick sprint (3kW for 30 seconds) once in a while and no mountains. I can now see how much overkill the 18FET controller is, but it should run cool (and so, long, hopefully)
