flippy
- Joined
- Aug 12, 2015
- Messages
- 2,351
yes i do have the curve:
https://drive.google.com/open?id=1v8PGphx0BzGzPJsUpUzXVG9fTgijW61g
the sawtooth shape is due to the temperature changes in the room over time. once you average out those changes you are left with no measureable differences in usable capacity. even if you take in any percentages in measuring error you are still left with a cell that has basically the same usable capacity since day 1.
i have a much more "worn out" set of 29E's that have done about 1200 cycles in a actual vechicle with loads between 0.7A continous and up to 10A peaks but has been charged no more then 4.05V and discharge usually no more then 3.3V that has lost about 5% capacity wich is pretty great considering the abuse it got.
comparing those figures with the test bench numbers that are coming out of it keeps the notion standing that stopping the charging at 4.05V and charging at low currents is much more important then actual currents being drawn. if temperatures are kept within spec that is. i have no doubt that a pack with active heating to 30 degrees or so will preform even better. the old pack was used daily during winter and summer without any insulation and still preforms like new.
and the datasheet is running tests between 4.2 and 2.5V. my tests are between 4.05 and 3V so dont compare those.
