LightningRods
For the regular Big Block I’d recommend an ASI BAC2000, a Nucular 12F or a Trampa 250 VESC. All great controllers and none of them work well with the Cyclone motors. The ASIs are a living pain to set up. Fortunately Greg at the High Voltage Group has produced a great tune for my motors as well as a plug and play wiring harness. You should be able to plug it together and go ride. For the time being they are using an Eggrider display.
My drives do not use freewheels on the motor so regen braking is possible. The big difference between my drive and the others, other than the obvious power difference, is that my drives are designed to optimise the performance and reliability of the motor system. No clutches or freewheels to wear out or break, gearing that is correct for the motor instead of pedaling, and enough power to make single speed riding fun. The CYC, the Cyclone, and also the Bafang drives are pedal assists. The gearing is compromised to work with 100 rpm human power. Other than matching pedaling cadence there is no reason at all to over reduce motor speed and then have overdrive final gearing to increase wheel rpm. It only creates driveline stress and problems.
